I use columns to get user input. Usually, the left column contains plain text describing text fields, and the right column contains those text fields. The height of the text field is bigger than the heigh of the plain text, causing left and right columns to misalign.
How can I avoid this? Is there a way to keep both columns aligned?
The easiest (only?) way to get around this is to use a table.
Actually, you could also make sure that you only have one paragraph in a 2 column set
Start a new question and answer in a second 2 column set.
The table is definitely not an option. I tried the one set per paragraph approach in the past but then the look and feel goes really bad because all that empty space between sets. Is it possible to get rid of that space?
