Can we have the ability to align text? I would like to align some text to the right for visual reasons but cannot
here is what I want
Here ius what we have
here is what I want
second this. Tables look so much prettier and readable when we can have consistent alignment.
Since we’re talking about aligning things, I also drop a suggestion to allow to center vertically within each cell.
Here’s an example. Left is current alignment of a button, image and text. On the right is a quick fix after aligning everything vertically.
Regarding the original request @Colin_Nickerson, you can do this in formula columns with this trick:
Create a template like this:
Use it in a format like this:
Format(
@Right-aligned.Template,
"Your text"
Voila:
Now, my feature request would be to be able to force column headers (names) to the right. So far only numerics are right-aligned but sometimes I want to do numeric-like values like that also right-aligned.
Same here. New to Coda and liking it so far, but this is a pretty basic formatting feature.
Yes please. My use case today was centering a concatenated set up buttons in a detail view. Thx!
It’s so weird, each time I come back to Coda and try to use it, I just find more basic features like this completly absent… I can’t really understand how there is still no feature to align text or values in a column… Crazy…
Just realized there’s a slightly more simple and elegant way to solve this need with a custom pack column format:
