I would like to create two different detail views of the same table. I have a table for work meetings. For past meetings, I want to show sections for meeting notes, questions and summary. For future meetings, I want to show fields that help me prep an agenda or input an agenda that has been shared, participants, etc. Every time I change the detail view for past meetings it changes the detail view for future meetings and vice versa. So each time I have to update what columns are displayed, which is a big pain in the neck. Please help!
Hi @Margarita_Alonzo
You can create 2 different detail layouts (with different configurations, showing/hiding different fields, etc…) and apply one to the view you use for your past meetings and the other on the view you use for the future ones
There are multiple ways to create layouts so, here’s just one of them
For the first view you’ll see in the sample below called [Past Meetings (View)], I clicked on the Display which appears when hovering the “title” area of the view …
This opened the Detail display menu where I clicked on the button Edit layout.
Which took me to the Layout Editor while creating a brand new layout called Layout 1 where I renamed the Layout 1 into something more suitable, and configured it as I wanted…
For the future meetings in the view called [Future Meetings (View)] I followed the same path :
Display → Detail display menu …
… and in the dropdown under Layout I chose the option + New layout.
… Which once again took me to the Layout Editor where I renamed the layout into something else and displayed what I wanted and how I wanted it
So I now have the layout Past Meetings applied to the view [Past Meetings (View)] and the layout Future Meeting applied to the view [Future Meetings (View)] ![]()
I hope this helps ![]()
Wow! Thanks a bunch. I followed your guide and it worked perfectly. I was running in circles and getting frustrated. Having this will help me have a place for all my meeting notes and prep. Thanks again!!
My pleasure @Margarita_Alonzo
I’m very glad to know it helped you moving forward
