Hi,
For example when creating a new button “modify rows”, you have to select a table to apply the button to. This is a simple dropdown of which the width is quite narrow.
In some docs I have over 100 tables.
Some of those tables have the same preface.
So the only way to find the correct one is by hovering over each of the ones with the same table until I see the correct one.
This would be resolved by having a type-in search to find the correct table in an instant by using a specific keyword that’s mentioned in the table name.
Cheers,
Sonny
