In a table cell having multiline and formatted text, I am unable to move cursor up or down from current line using arrow keys. Also I couldn’t move cursor to start/end of current line using home/end keys.
When I checked the console while pressing above keys, following error message gets printed for each key press.
TypeError: Cannot read property ‘top’ of undefined
When I delete one of the lines by pressing backspace key repeatedly, following error page is shown.
Thanks for the reply. I am still facing the issue. This fix appears to solve different bug where lookup column is uneditable. In my case, I can edit the cell contents in concerned column which has text as its type.
I have initiated the discussion with support team as well.
