Updated Spotify Features! (9/13/2019)
We’ve been getting great feedback since our Packs Launch and wanted to add a few more features.
The Spotify pack now has a parameter to allow you to filter the Playlist Tracks sync table to a single playlist. This is helpful if you have a lot of playlists and don’t care to sync thousands of tracks, or if you’re hitting performance issues. You can use autocomplete on the parameter to narrow down to the single playlist you want.
You can also add multiple syncs, each with a single playlist, to sync multiple specific playlists.
We also added backend rate limits to try to avoid sporadic rate limit issues that customers are seeing, given that Spotify has rate limits but doesn’t publish them.
Let us know what you think!
@BenLee can you see a future where Coda can interact with the embed and trigger play/pause? :slight_smile: :musical_note:
It can actually!
