Hi,
I was wondering if someone could tell me how to use FormulaMap to add n rows to a table, with each row using a value from the multiselect control.
At the moment, I have managed to write a formula in a button that takes the values from a multiselect control and will add the correct number of rows, will map the correct collumns, however, where I am getting issues, is all the selected options in the multiselect is inserted into the one cell, then the second row is the same…
