Had a strange one while fiddling with my doc this afternoon.
I changed a column name to include an instruction to users - in brackets.
So the column name went from Workflow to Workflow (optional)
Anyway - cut to a few hours later and I was testing a bunch of formulas and the like, and noticed that two lookup formulas were no longer working. Perplexed, I assumed I had changed something in the formula… but try as I might, I could no longer get it working.
Then it hit me - I wonder if my use of brackets in the column name upset things.
And - once I had changed it back, sure enough - things started working again.
So my question is - is there any way of using brackets in a column name without it breaking formulas? I guess I just like the use of brackets to give a “hint” to a user.
Or is there another way to provide hints to users? I come from notion where that was quite easy, but I just haven’t come accross anything here yet that gives similar functionality.
Thanks for everyone’s help.
