Hey Folks,
A weird white line is cutting across the card view in one of my docs. Has anyone encountered this?
Update
I took a look at it via Chrome’s dev console, and apparently the div that creates a gap between the groups is not behaving as expected:
I deleted my cache and files, but that hasn’t fixed it. Any ideas on what might be going on?
I ran into this too, it appeared a couple days ago. Took a long time to find it, thought it was something with my columns, but it’s clearly a bug
Were you able to find a fix?
this is clearly a ux bug.
if it persists, you should report it to coda.
use the questionmark button bottom right on your screen.
max
I can confirm that this bug has now been resolved. Thank you to the Coda team!!!
system
Closed
6
