Difficulty moving card in "card view"
Hello,
I’m having a bit of a hard time moving cards arround in “card view” when they are grouped (see picture). Two times out of three the card doesn’t move and my cursor either selects the text arround or enter the detailed view of the card !
Anyone had this issue yet ?
Thanks in advance
Thanks for reaching out to let us know about this issue. This sounds like it might be related to a known bug the Coda team has identified. That said, we have moved this post to the Suggestion Box: Bugs section of the Community and somebody from the Coda team will be following up with any updates on this issue. Thanks for hanging in there!
We just received news that this bug has been resolved! Can you give it another shot and please let us know if you run into any issues?
It works ! Thank you for your reactivity !
@Shaina_Torgerson - Not sure whether you consider this a bug, but dragging cards does not work in sync pages - I.e. I can drag the cards in the souce doc page but not in the sync page version.
