Heres a weird one. When I try to move a card from one column to another it doesn’t want to update:
Heres the link with support share turned on: Coda | Everything evolves, the evolution of documents.
I think this is a bug. I had it happening in my docs yesterday too. I Can confirm!
My client is also experiencing the same issue now !
Bump. This is still happening !
I am seeing this too; all my tables using the Card view are broken. I created a new sample table grouped by a simple Select List Column, and dragging updates the value in the table, but the UI does not update to reflect this until the page gets refreshed.
Hi @Harry_Roper, thank you for reporting this bug.
It has been reported and fixed, the fix should go live today around noon PST.
Thanks.
Legend @Jesus_Guzman , cheers!
Was it fixed @Jesus_Guzman? I’m having the same issue. I use Arc.
@Jesus_Guzman I just tested this on a new doc and a new board and am still able to re-reproduce this issue.
We got this bug today! Dragging works in horizontally grouped cards, but doesn’t work in vertically grouped ones. Coda, help please
We use Arc and Chrome.
