I had a card and a table view of the same table.
Card view was grouped by a Select column with Show Empty Groups turned on.
I tried reordering the groups then it showed a warning saying that I should reorder the select options instead. I did that, but the groups on card view didn’t update. Tried refreshing the browser, didn’t work. Then I finally turned of Show Empty Groups and turned it back again, then it worked!
