This automation doesn’t work, am I missing something?
What should happen when the automation runs? Right now you haven’t told it what to put in the various cells of the row that’s gonna be created.
Don’t forget to turn it on with the switch at the top (I do this all the time )
You can check the logs (activity? History? I forget what it’s called) tab to see when it was triggered and what it did (or tried to do).
Hello, for some reason I came back the next day and worked like nothing ever happened
