White screen in Edge, "application not running" error in Dev Tools
For the past month, I’ve been unable to use Coda in Edge (131.0.2903.86 version). Navigating to coda.io the URL switches to https://coda.io/docs/ and the screen is all white. I’ve even logged in using a private window and I get the same thing. Looking at devtools, I get the following errors in the console:
background.js:12 application not running
(anonymous) @ background.js:12
o999875.ingest.sentry.io/api/6006079/envelope/?sentry_key=650ad5569e6b44168c6750dad16368a8&sentry_version=7&sentry_client=sentry.javascript.react%2F7.120.0:1
    Failed to load resource: net::ERR_BLOCKED_BY_CLIENT
Refused to execute inline script because it violates the following Content Security Policy directive: “script-src ‘unsafe-inline’ ‘unsafe-eval’ https: ‘nonce-TXXa0ZZ8XWdg13Fye0/UlQ==’ ‘strict-dynamic’”. Note that ‘unsafe-inline’ is ignored if either a hash or nonce value is present in the source list.
docs:4 Refused to load the script ‘https://cdn.coda.io/assets/website.61e4e2d8c92ccb14fa25.entry.js’ because it violates the following Content Security Policy directive: “script-src ‘unsafe-inline’ ‘unsafe-eval’ https: https://.mutinycdn.com https://.googletagmanager.com https://cdn.cr-relay.com/ https://*.getkoala.com ‘nonce-TXXa0ZZ8XWdg13Fye0/UlQ==’ ‘strict-dynamic’”. Note that ‘strict-dynamic’ is present, so host-based allowlisting is disabled. Note that ‘script-src-elem’ was not explicitly set, so ‘script-src’ is used as a fallback.
docs:1 Refused to load the script ‘https://cdn.coda.io/assets/website.61e4e2d8c92ccb14fa25.entry.js’ because it violates the following Content Security Policy directive: “script-src ‘unsafe-inline’ ‘unsafe-eval’ https: https://.mutinycdn.com https://.googletagmanager.com https://cdn.cr-relay.com/ https://*.getkoala.com ‘nonce-TXXa0ZZ8XWdg13Fye0/UlQ==’ ‘strict-dynamic’”. Note that ‘strict-dynamic’ is present, so host-based allowlisting is disabled. Note that ‘script-src-elem’ was not explicitly set, so ‘script-src’ is used as a fallback.
docs:1 [Deprecation] -ms-high-constrast is in the process of being deprecated. Please see Deprecating support for -ms-high-contrast and -ms-high-contrast-adjust - Microsoft Edge Blog for tips on updating to the new Forced Colors Mode standard.
docs:1 Unchecked runtime.lastError: The message port closed before a response was received.
The resource was preloaded using link preload but not used within a few seconds from the window’s load event. Please make sure it has an appropriate as value and it is preloaded intentionally.
guidde.js:2
    POST https://o999875.ingest.sentry.io/api/6006079/envelope/?sentry_key=650ad5569e6b44168c6750dad16368a8&sentry_version=7&sentry_client=sentry.javascript.react%2F7.120.0 net::ERR_BLOCKED_BY_CLIENT
(anonymous) @ guidde.js:2
add @ guidde.js:2
o @ guidde.js:2
_sendEnvelope @ guidde.js:2
_flushOutcomes @ guidde.js:2
t @ guidde.js:2
(anonymous) @ chrome-extension://p…eIframeService.js:2
add @ chrome-extension://p…eIframeService.js:2
o @ chrome-extension://p…eIframeService.js:2
_sendEnvelope @ chrome-extension://p…eIframeService.js:2
_flushOutcomes @ chrome-extension://p…eIframeService.js:2
t @ guidde.js:2
(anonymous) @ chrome-extension://p…kActionService.js:2
add @ chrome-extension://p…kActionService.js:2
o @ chrome-extension://p…kActionService.js:2
_sendEnvelope @ chrome-extension://p…kActionService.js:2
_flushOutcomes @ chrome-extension://p…kActionService.js:2
guidde.js:2
add @ guidde.js:2
o @ guidde.js:2
t @ guidde.js:2
t @ guidde.js:2
guidde.js:2
add @ guidde.js:2
o @ guidde.js:2
t @ guidde.js:2
t @ guidde.js:2
Any help for a resolution would be appreciated.
Hey @Darin_Levesque ,
I have almost the same Edge browser version:
and for me it runs fine - in standard or private mode.
Reading your dev tools printout, it seems to me that it must be a local extension that is blocking coda from running - or something in your computer’s firewall or a window security setting.
Greetings,
Joost
