I’m trying to make a tool that will allow me to select recipes I want to cook for the week + servings I want of each recipe and populate a shopping list with all ingredients I need for those recipes.
I have a table: ingredients_recipes that stores all ingredients needed for each recipe + the quantity of each those ingredients. I then do some fancy stuff that allows me to select the number of servings that I would like for a particular recipe. Using a formula, that results in the column total_quantity on table ingredients_recipes which tells me the total quantity of a given ingredient I need for each recipe. ALL good. No problems there.
Next step: build the shopping list.
Because some ingredients will be repeated between recipes, I have a separate table (shopping_list) at the grain of ingredient. I’m using a formula to sum up the total quantity of a single ingredient needed from the ingredients_recipes table to populate the total_quantity_to_buy column on the shopping_list table.
**ingredients_recipes**.filter(**ingredient**=thisRow).**total_quantity**.Sum()
Here’s the catch. The table ingredients_recipes stores ALL the ingredients for all the potential recipes I could cook and their quantities. Currently the above formula will sum the total needed ingredients across ALL recipes, not just the ones I’d like to cook this week. On ingredients_recipes I have a column called planned_day_meal. If that column = “Unassigned,” that means I WON’T be cooking the meal that week and that ingredient row shouldn’t be included in the shopping_list table calculation. I thought using the below filter addition would allow me to exclude ingredient quantities that are currently categorized as “unassigned” but the value of total_quantity_to_buy doesn’t change when I add this additional argument:
**ingredients_recipes**.filter(**ingredient**=thisRow && **planned_day_meal** != "Unassigned").**total_quantity**.Sum()
Essentially without the qualifier of planned_day_meal != “Unassigned” , the value for total_quantity_to_buy for the chicken breasts row is 6.75. When I add in the qualifier of planned_day_meal != “Unassigned” I would expect the value for total_quantity_to_buy to go down to 6 but it stays the same (6.75).
Not sure what I’m doing wrong here. I’ve gone through a million coda threads to try and find a similar solution with no luck.
