Wildcard in filter?
Hello everybody,
I have a problem filtering a text field and I just can not go on:
For example, in a table in a text box, the value is "XNTB ASUS PRO
B53A-SO056X ".
Now I want to set a filter that shows me all records, if this field contains “ASUS”. Normally this is very easy to do in databases with a wildcard, but I can not find anything in Coda and my attempts are not successful.
Greetings Max
Here’s an explanation:
Yes, that works!
Thank you for your help
Greetings from Cologne / Germany
Max
