Will I get a message if a user clicks button with Notify(me) action on published doc in play mode?
Hi @Tomislav_Mamic
After some tests, I’d say no …
Changes are not saved in play mode. So, the user will be able to push the button, but the action will not run.
Thanks! I wonder if it would be useful to enable this… For example, to test how many users click on a certain button in your doc.
No problem
I don’t have anything specific in mind right now but I’m pretty sure this is something I wished I could do once in a while
But I guess, before having such a feature available, we would need a better control over the permissions than the one we current have
You can use locking (team plan feature) and interact mode, then you can have buttons record whatever you need. Play mode by definition doesn’t change the doc at all.
