1-way Sync for Okta
Hey team, has anyone set up a 1-way sync via Okta (or your IdP) for an employee table in Coda? The Okta plugin appears to be a 2-way sync, and I suppose I could just set permissions on the Okta API key to be read-only to prevent Coda from writing to Okta. I mostly want an employee table I can use for referencing things like job titles, managers, departments, etc.
Hi @Erica_Anderson , thanks for reaching out! It seems like not toggling “Allow two-way edits” to ON should do the trick as shown below:
Can you please give that a shot?
