7-Step Guide to Secure Your Coda Document
Hello Coda-Community!
After making several posts about Coda’s default settings and the security issues they can cause, I’ve put together a short guide to secure your Coda documents. I created this as a template for our schools / teachers that are using coda.
The attached Coda doc details the critical settings you need to adjust for optimal security. By following these steps, you can prevent unauthorized access, copying, and sharing of your documents. If you have any additional tips or if there’s something I’ve missed, please share your thoughts!
Greetings
Thanks for the valuable information, especially the essential settings you described in the first two steps. Some users may not know where they are.
