I’m a big fan of the ability to quickly add a control from the “filter” menu (see screen grab), but in the past couple of days it doesn’t seem to be working for me- I’ve now tried multiple docs & browsers and nothing seems to happen when I click “create control”… I thought maybe it was creating one but hiding it somewhere but that doesn’t seem to be happening either. Anyone else experiencing this?
Hi Alex, thanks for writing in, this is affecting lookup columns only.
Engineering team is already working on a fix.
In the meantime you can create a control manually to filter your table, we should have a fix soon.
I will keep you posted on the same.
Cheers!
Jesus.
amazing thanks! I had no idea how much I relied on it until it was gone
