I found a scenario in which there is a bug with Activate() when adding a row to one table and then associating that new row in an AddRow() for another.
The expected behavior is that Activate() will open the row it’s tied to, which I wanted to target to the parent table row, but it actually just opens the child table row every time.
The solution is to use a Relations canvas control, which I’ve also documented here:
