Hi everyone!
I couldn’t find any doc with the feature I’m trying to create so I’m asking it here:
Is there a way to add multiple rows with a button like in the example below? Feel free to edit it as you want, we need this so bad
Thank you
Hi everyone!
Thank you
Disregarding the business logic, here’s a doc you can play with specifically for adding multiple rows with a button. Review the column settings, as most have been changed. See the section called "changed".
This is perfect, thank you so much @Ander
