Hi Coda Community,
I’m having trouble with automations involving two columns in my table:
Recording Date (type: Date): This column stores the relevant date for each item.
Recording done (type: Checkbox): This column should be checked automatically if the Recording Date is before today, but I also want the flexibility to manually check or uncheck it as needed.
Here’s what’s happening:
If I use
[Recording Date] < Today()as a formula in the “Recording done” column, it works perfectly—but the checkbox becomes read-only and I lose manual control. -
If I try to use the same logic in an automation (trigger: Row changed on Recording Date, If:
[Step 1 Result].[Recording Date] < Today()), the condition always returns false—even when the Recording Date is before today. -
If I set the If condition to just
true, the automation runs, but does not update the checkbox value.
My goal:
I want “Recording done” to be automatically checked if “Recording Date” is before today, but I also want to be able to manually check or uncheck the box if needed (so a formula-only solution isn’t enough).
What I’ve tried:
Verified both columns are correct types (Date and Checkbox)
Tested with new and existing row
The formula logic works in a column, but not in the automation If step
Is there a workaround for this? Any advice to achieve both auto and manual control would be greatly appreciated!
Thank you!
