i recently made a few automation and i delete them and im still receiving mails
how i stop the automation after delete
Hi @Roy_Ribak - when you click on the notification it takes you to the doc with the automation in it. Can you see if you maybe have a copy of the doc where the automation is still enabled? Once you delete an automation it stops working.
I still get the mails after it been deleted
Roy Ribak | 0545507799
Could you please share the doc with support@coda.io and also fwd a mail you are getting.
Done
Could you forward the email from the notification too please.
Whats your email address?
תודה מראש,
רועי ריבק מנהל שיווק קבוצת איינשטיין
רכבת צפון (בר)
מילבה (בר)
אגאדיר באר שבע
הפקת אירועים
0545507799
You can forward it to support@coda.io
Hi @Roy_Ribak - your automation is being fired from a different doc than the one shared with me.
At the end of an automated email it says - Sent by this Coda Doc. You can click on it to see which doc triggered the automation.
Ok i remove it, thank you
תודה מראש,
רכבת צפון (בר)
מילבה (בר)
אגאדיר באר שבע
הפקת אירועים
0545507799
