I’m stumped. My client’s doc is extremely slow and the first item that shows up when measuring doc performance is a view of a table and it says “System Property (default value)”. Then the next item says “System Property (value)”.
Since there are no columns in that table/view called System Property, what the heck is this and why is it taking 2 minutes for the doc to process these two items?
Do you happen to have a canvas formula in the slow view of your client’s doc ? (or a canvas control)
I remember stumbling upon System property (value) and System property (default-value) some time ago while testing a structure/workflow for one of my doc and after the very quick test I just ran, it seems to be linked to canvas formulas/controls.
(I have no idea what they both do though )
