I’m wondering if Coda can help me with a significant research project. I’m exploring Notion, Coda and Curio.
Background
I’m working on a large book project. I have collected a lot of digital research/resources. The material is primarily in one of three formats: PDFs, plain or markdown files, or archived web pages.
Currently all of the documents are in folders/sub-folders in iCloud and accessed through the Finder or through the Files App. They were originally in DEVONThink but I was having syncing issues on iOS so I moved everything out of DT to iCloud.
Currently Used Primary Apps
- Scrivener–my long form writing app on iPad Pro and the MBP
- MindNode
- PDF Expert
- I’ve downloaded a trial version of Curio but have only tried a few ideas in the app. I don’t have an opinion on this app yet.
Possible Ohter Apps to Use
- Curio?
- Coda?
- Notion?
- Roam (the subscription price is too high for my tastes)
- Other?
Requirements
- Cross platform MBP and iPad syncing in iCloud
My struggle
I may be making this much harder than it needs to be. What I’m trying to do is review each research document related to a particular topic, say team dynamics and cull out the important ideas from the document into a system so I can manipulate the information around and connect it to create final headings and subheadings for each chapter I’m working on.
I’m trying to capture a visual outline or mind map of the ideas/concepts/quotes so I can connect them by copying/pasting/dragging them into an application so that the resulting content does not require reopening the source file. If I use a mind mapping app or free form canvas app like Curio, Coda or Notion, then I only want to type (or cut/paste) a few words with the remainder of the content embedded in the app or branches of a mind map for quick reference.
Ideally I want to be able to export the results into each chapter in Scrivener as headings/subheadings. From there I’ll start the writing. I’m looking for a “bridge app” between the research documents and Scrivener to ensure I capture and connect all of the major ideas, facts, and concepts from the research into appropriate conceptually connected headings/subheadings for each chapter in the book.
Now here is where I may be making this harder than needed. In the “good old days” I had a stack of books and research literature for my dissertation stacked everywhere and I took notes, arranged them in legal pads or note cards, and then started writing. I can certainly do something similar again but I’m hoping there is a better way given all of our new digital tools.
Any best practice advice will be appreciated!
