I know it can highlight for other columns ( Habit, Duration …) .
But I just wanna only highlight for Grouped field , bcz other columns use other colors.
Is this a bug ?
Is this a bug ?
Not a bug, just a feature never made, I think. Conditional formatting doesn’t work for group labels.
I’d also very much like that to work. Would be very helpful to color code groups.
Thanks reply.
I’m waiting for update.
This would be a nice feature. The way Coda groups rows, and allows you to collapse or not, really gives great context to looking at a table. Being able to roll up the conditional formatting to the groups would add even more benefit to this!
