Has anyone tried to build Coda Packs with AI (ChatGPT)?
@Bill_French probably has
And I actually built this auto-schema generator doc that generates Coda pack schemas for you using Coda AI
Overall though, I wouldn’t recommend it. Chat GPT, given proper prompts and examples, might be able to get somewhat close to working pack code - but I would really suggest the user having sufficient knowledge about APIs and Coda Packs to adjust, modify, and fix code provided by Chat GPT
Thanks for sharing @Scott_Collier-Weir ![]()
