CODA Automation problem
Hi there! I’m currently working on a formula to set up a slack automation to send out reminders as contractors’ end dates are approaching. I’ve set up columns for:
  1. Team Member
  2. Contract End Date
  3. Button for slack
  4. Messaging to be sent to slack once it’s been triggered
and also turned on the automation for this. The problems are;
  1. The messaging formula isn’t working. I wanted to customize it and pull info from Team Member and Contract End Date. And message should say ( “Team Member”'s contract is expiring on “Contract End Date”. Please reach out to their managers to discuss next steps. )
  2. How do I customize a button formula to only light up when it’s 2 weeks prior end date and only 3 days prior end date.
Hi @Gen_Garcia,
It would be very helpful if you could share a dummy doc.
Let me rephrase that to see if I understood: do you want a button disabled except when today is 2 weeks before the end date or later?
