Hi there
I wonder if anyone can help… I have 2 tables set up in timeline view, which I want to be able to combine in order to easily see how the time periods compare. Any ideas? Is this possible?
Many thanks in advance for any suggestions.
Hi there
Hi Kathryn, do they have to be in separate tables? The easiest way to compare them is if they were in one master table, and you can always use a label or some other way to group or filter them so you see them separately.
