Is it possible to create conditional formatting of column select lists based on a selection of one, say a parent control?
Use case:
We have a table with two columns, both select lists.
Column 1 is a parent selection (Fruit type) and column 2 is a child selection (colour). If user selects “apples” in the parent select list column A, then show “Red, Green” as select options in the child column B.
We could then have another folder with a table that is configurable. So we would have logic in that table that some how stipulates the relationship between apples and colours.
Any workarounds team?
