Coming from Airtable, when you use a multi-select for a column, each option could be set to a different color inside a cell. Is there a way to have each option be a different color so it’s easier to tell which rows contain a certain value?
+1 it would be really cool.
Conditional formatting based on the value works like a charm
Dear @Sean and @Huayang_GUO
This post might be of your interest:
Thank you this is helpful!
