Hello All,
Thank you in advance for looking into my question.
I am currently managing different tasks and resources and I thought that using sliders as part of the task monitoring would provide an extra visibility on the overall progress.
So far I only played with Status (Not started, in progress, on hold, cancelled, completed).
I am trying to link the status with a slider. Not sure yet which one should modify the other but I thought the status would allow to do the following:
- Not started = slider at 0 and not possible to modify
- In progress = slider can be modified with whatever value you want to assign
- On hold = keeps the current value but slider cannot be modified
- Cancelled = I guess it would be like “On hold”
- Completed = slider at 100 and not possible to modify.
I cannot get the formula to work therefore your help would greatly appreciated.
Thanks again
Hi @Johan_Bertin ,
and welcome to Coda Community!
Unfortunately you can’t “disable” an input field.
You can disable a button or provide a formula-based value/control (preventing it to be manually changed), but not mixing manual input and formula-based in the same column.
As a basic workaround I would:
- add a “twin” slider column formula-based reporting the slider value (therefore, read-only)
- filter a view with only editable tasks (status = in progress) showing the editable slider
- on the other filtered views (status != in progress) showing the non editable one.
I hope this helps.
Cheers!
Hello @Federico_Stefanato
Thank you for you quick reply. Then the deactivation would not be the main feature.
I am more concerned about the possibility to set a custom value when the in progress is selected and a custom one for not started and completed.
Thank you again
Hi @Johan_Bertin
I understand.
I think it’s a design perspective relying on how you wish to shape your application.
The two main ways could be:
- your interface is mainly action-based; i.e. the change of a status is through a button.
- pros: full control of the operations triggered by buttons and data consistency potentially higher
- cons: higher complexity in the maintenance because is full formula based in the button(s) and careful filtering out of the columns affected by button(s)’ actions.
- you check - and fix - consistency discrepancies on a scheduled automation; i.e. at row-changes or predefined intervals you run an automation that “puts back” discrepancy values for statuses that have default ones.
- pros: less overall complexity in the row design
- cons: might create a counterintuitive and deferred perception form a UX perspective (e.g. I change something that changes back…)
You can also add some visual features (conditional formatting) or notifications (again or row change or scheduled) warning the users for the inconsistencies.
Lastly, I believe that (for internal tool) some good discipline and habit are the best rules ever and keep the document light and flexible and the responsibility high…
Let me know what you think about it.
Cheers!
you are actually right.
I will perform the following then:
- Default value set up to not started and slider at 0 when a new row is created
- When changed to in progress, I will adjust the value of the slider accordingly
- To complete a task, I will create a button to change all the status to completed and slider at 100
Easier to manage and maintain the consistency of my document.
Thanks a lot for time you spent !
