Confusing Hour indication after calculation using Date and time format
Hello,
I’m working with Coda for a little while now and have been a ‘regular but silent’ :sweat_smile: community user so far… (Thank you all :pray:) Let’s see if I can start to contribute by means of the following doubt:
Using the date and time format, when trying to add a duration to get a new date and time, during the first hour after midnight the hour indication is displayed as 24 instead of 00 as you can see in the 3rd column:
Curiously the hours are indicated as 00 during selection and when converting to the Time format (last column). Why is it designed like this? Can the date & time format display the first hour after midnight as 00 after applying a calculation?
Thanks in advance!
P.S. Looking forward to the nested pages!! :grin:
Hi @anon41554251,
Thank you for posting this example and showing the issue happening in a doc. This looks like a bug and I was able to re-create it, so I’m adding it to our tracker.
Thank you for reporting it, and great to have you posting here as well!
Ben
OK. Happy to hear its not a limited function needing adaption on interpretation from my side. As I did not link it to a possible bug I guess I posted this in the wrong category… Marked your answer as Solution, because my doubt about how to change the formatted indication is gone :upside_down_face: Thanks!
