Connecting Shelly with Coda
Hello there!
I recently started to use Shelly and I wandered if there is a way to connect the data I get from Shelly to my Coda docs.
For those who don’t know it, it´s basically a company with some products that allow you to control electronic machines from your phone and with it you can get a lot of data. For example tables with temperatures, humidity and so on.
Is there anyone who has already done that?
Hi @Asaf_Chip,
I also have many Shelly devices, but don’t really use their app and have them integrated in Home Assistant instead.
I don’t think you will find anything that works out of the box unfortunatelly, you will need to tinker with Shelly’s API.
If you also have integrated your Shelly devices with Home Assistant, maybe this n8n integration could help you Coda and Home Assistant: Automate Workflows with n8n
But beware that sensor data can be thousands and thousands of data points depending on the frequency and pretty soon you may hit performance limits in Coda.
Hope this helps,
Pablo
Hey @Pablo_DV
Thanks again for the info and especially for the last note! I am planning to connect several devices and collect daily data so ill defiantly gonna have it in mind!
