I’ve got two table views on a page (different tables), both filtered with a control select thing using a formula. One of the tables is filtering properly (the bottom one), the other isn’t (top one).
Can’t figure out what the issue is.
Would love some help if any of you out there are bored… Here’s a link to the page:
Hi Kelly, I just requested access to your doc
Given! Let me know if you have problems getting in…
I can get in, it just looks like I need access to copy it so I can check your formulas!
Kelly, sorry for the delay! The first table isn’t filtering properly because Title Formula is a text value of a column, while FindProposal 2 is a row. You can see that in the icons that trail each formula element. To force it to look up a row, change
Title Formula.matches(findProposal 2) to
thisRow.matches(findProposal 2)
However, it’s worth noting that this only works if you have a single row that matches the Proposal. Otherwise, you will have to use a different formula.
The second works, by the way, because you’re comparing multiple rows to a single row
