Is there a good way to export data from a card based view into csv?
With tables easy enough to copy and paste, but card view does not paste single rows per card and it’s difficult to see the highlight.
Is there, for example, a button function viewers can use to toggle to a table view?
You could use @Courtney_Milligan1 ’s export pack perhaps!
Thanks for the mention @Scott_Collier-Weir!
@Nick_Short my pack is called Export Tables, and it should work regardless of your table layout. Let me know how it goes if you try it!
system
closed
#4
