I love all the templates out there. What I’d like to do is to take some of them “home” with me and put them into a single project. For e.g. a CRM + content inventory. I’m brand new to this, so I don’t know if there’s a way to copy one template’s features into another document.
Hi @agoodman,
It is not something easy like dragging and merging them but do take a look at this post and see if it helps you Merge two docs or copy one doc into another
Thank you for the tip!
