Is there a simple way to copy my documents automations to a new doc or do I need to keep re-creating them?
Not a simple way but you can turn your document into an in-page template, delete everything but the automations from that template, publish it as an in-page one, and then import that template into your destination doc.
I remember this used to work, although I’m not 100% sure.
Thanks for the quick answer Paul.
