am trying to create all possible appointment slots but cant seem to piece together whole flow with sequence formula and have tried withname, formula map, for each, helper table
end goal is after entering start and end dates, then pressing create availability slot button would add to Appointment Slots table of possible combinations (have filled out manually appointment slots table for desired end result).
Added a playground demo doc below:
any insights/teachings would be greatly appreciated
Iāve made a copy of your doc and have updated the [Create Availability Slots] buttonās action formula so that it works as youāve described. Iām not sure what the HLP Availability Slots table is for, nor the BTN Create Slots button on the Availability Schedule table. Iām guessing those were both intended to break the problem down into smaller chunks. I didnāt end up using either of those - everythingās in that big red button.
The button formula does a lot, so itās quite long. Thereās no real way around that! In cases like this, I find it INVALUABLE to use WithName() to give yourself well-named variables to work with. That helps break the problem down a bit, and makes the overall formula a bit easier to read.
The only other trick here is dealing with rows in Availability Schedule that have blank Start Time, End Time or Availability Types columns. Those would break the logic so thereās an If() block that checks those are valid, and IfBlank() run a hidden action formula called _NoOp(). This formula basically ādoes nothingā so itās useful in cases like this where youāre looping through valid/invalid rows and donāt want your action to break execution half way through.
Hope itās easy enough to follow, but if not, feel free to reach out. Hereās my copy of your doc with the updated [Create Availability Slots] button action:
