Employees
Every Employee needs to have its own calendar due to internal rules.
We have 125 employees. Yes, it results in a big table “MasterServiceCalendar”, but it works now for two years.
To create new calendars for the next year, I have created a select-control (S_Employee) from the employees table and a date control (S_Date) to select a fixed date range.
What I want to achieve is via a button:
Depending on which employees are selected in the list control and depending on the date range (first/last) I want to add rows in the table MasterServiceCalendar for each employee in the selected date range. Maybe I need to split it in two charges because of the data amount.
By example:
Employee1 → add 365 rows in MasterServiceCalendar → Employee2 → add 365 rows in MasterServiceCalendar
It is no problem for me to do that for a single selected employee, but if I have multiple employees selected, I run in problems. The Employee list needs to be finished step by step.
Has anyone of you an idea, how a formula for this could look like?
Hello @Foerster_Matthias ,
What you want to do is create a formula that looks something like this:
S_Employee.foreach(sequence(start_date_range,end_date_range).foreach(addrow(MasterServiceCalendar,column 1, value 1, column 2, value 2,…)))
If you have a hard time doing this, make and share a dummy doc and we can show you how to do this.
In order to prevent duplicates, you could use AddOrModifyRow() instead of AddRow
Thank you @joost_mineur for your help.
I had something similar in mind, but I failed in my version at the same point.
As soon, as I select multiple names from the employee list, it creates entries in the MasterServiceCalendar with one date row, but combined employee names.
I tried to recreate my structure here:
Can you please have again a look on it and try to find my mistake?
What I try to achieve is, that every employee gets his own range of date entries.
Dear @Daragh_O_Shea1 , that was exactly what I needed. It works perfectly. Many many thanks for your time and effort. I’ll analyze the formula difference and dive deeper in this “WithName” which I’ve nerer used till now.
Just for completeness sake, I added two more buttons and changed AddRows() to AddOrModifyRows(). Reason being: if you (or another user) hits the button again or tries to create an identical range or an overlapping range of calendar items, you get an enormous amount of duplicates. So I created the new buttons to prevent this. The buttons look similar, but they are not: button one finds existing event rows matching the selection criteria and overwrites them, the 2nd button finds the same existing rows but leaves them alone.
Both approaches serve there own purpose, as you will see when you start playing with your test doc.
