Creating a way for a team to rank a set of options
Hi,
I’m trying to have everyone on my team stack rank a set of options before we meet. What is the best way to do this? I don’t want people to see what others have ranked before they rank. If I could have the ability to add additional options, that would be awesome.
Thank you! Roseanne
Dear @Roseanne_Wincek welcome in the Coda community :handshake:
I recommend to check out the “Voting Template” that you can find in the in-doc templates under the “Explore” link at the top right of your page.
This should be a great foundation to start from.
In case you need more support, feel free to let us know.
Thank you for the fast response! Super helpful.
What I am trying to figure out is how to let people vote without seeing everyone else’s answers. Is that a settings issue?
I recommend to checkout this template and in general the template section is a big resource to find use cases that might (with some corrections) applicable to your environment.
Credits: @jerols
Additional I recommend the short videos from @maria, like this sentiment tracker:
Hi @Roseanne_Wincek,
You can achieve this by adding a column User containing the active user, and then filtering by it.
A pretty similar example could be this one:
Feel free to ask if something is not completely clear.
Hi Everyone,
Thank you for all of the help and answers. I think where I am getting stuck is that I want to have a fix set of rows - I.e. the attributes being stack ranked, and I want each person to rate each row 1-5 without seeing the other’s answers. Most of these are about allowing answerers to add rows, which I don’t want to do.
Thanks, Roseanne
Hi @Roseanne_Wincek, I have a template here with another pattern that you may be able to adapt:
The key step is “3. Stack rank”, where each person adds a row for each item to include in their rank and orders the rows to reflect their desired ranking.
