Bonjour,
I’m using the metadata API of Coda to READ the schemas of tables.
This is really cool.
What I would like to do now is to CREATE new tables/columns.
Unfortunately there are no API endpoints for that.
I’m new to packs. I’m wondering if it is possible to create a pack that reads a file or whatever with table description and then automatically create tables in a doc?
I’ve started to read the SDK documentation but so far I’ve not found the answer to this question.
Many thanks for your help!
Regards,
Jean-marie
