I would like to make a pack that accesses an API to retrieve data - that is pretty straightforward.
I would also like to have the tables created by the pack include AI columns. Can I define the AI prompts as part of the pack design, or do I need to re-enter the AI prompts manually from the Coda UI every time I create a new table using the pack?
@Richard_Kaplan - Unfortunately itβs not possible for a Pack sync table to define formulaic or AI columns that should be included automatically. You can however publish a template that include the sync table with the additional columns already setup, and just instruct users to copy that template.
Thanks @Eric_Koleda - I will give the template a try
