I have a table “suSuppliers” cross-doc’ed from Doc A to Doc B, that started to consistently fail to sync. The source table has only 350ish row and 40ish columns, so I don’t think it’s too large, and yet the sync fails with this error:
There are other tables in Doc A crossdoc’ed to Doc B and using the same account continue to sync without issues
Changing the sync account does not solve the problem
Manually or automatically syncing both result in the same issue.
The source table has not recently had any structural changes, just a couple more rows added.
Prompt assistance would be greatly appreciated as this is a business critical doc and we’ll be stuck for the day until the issue is resolved. (and we are 12h ahead of San Francisco…)
Limit on individual rows of around 70 KB — I presume there could be a row object (JSON parcel of a row) that exceeds this limit.
Try filtering out large rows / hiding columns with large data and see if it helps. If not, ditch the guesswork and contact support through the ? button. They’ll have access to verbose logs and can find the exact cause but you’ll probably have to wait.
Thanks @Paul_Danyliuk your reply put me on the right track,
hiding a bunch of columns in the source table worked to solve the issue.
It is an unsatisfying solution though, for the following reasons:
The source table was the main table, not a view
_ The reason for that, is because I wanted to be able to use cross-doc actions to edit the source table from the destination doc. And as you know, cross-doc only allows this if the source table is not a view.
For my sanity and as part of our best practices, we like to keep the original table tucked away in a hidden page and with all the rows unfiltered and columns unhidden. This makes iterating the doc design easier, rather than have to go on a hunt in different views.
→ Is this something that Sync Tables Pro could address in the future? Let me share a view to a different doc, but be able to sync actions/modifications back to it?
PS: for the developers of Crossdoc pack: this error message is poorly worded. For the end user of the pack, crossdoc sync is not an automation (although I understand that under the hood it may be), and it definitely does not make changes (as it only updates a table).
Worth thinking rewording the message to say something along what Paul wrote above.
