I’m slowly moving from Google Sheets to Coda, bit of a learning curve – but looks promising.
In GSheets I have a custom formula to convert units into categories.
20 a units = 1 b Unit
8 b units = 1 c unit
So value 20 will result in an output of “1b”
Value 180 will result in an output of “1c 1b 5a”
I achieved this in GSheet’s script editor:
function COINCAT(input) { var stringout = "" var n = input; var c = Math.floor((n/160)); var b = Math.floor((n - (t*160))/20) var a = n-(t*160)-(c*20) if (c > 0) { stringout = c + "c" } if (b > 0) { stringout = stringout + " " + b + "b" } if (a > 0) { stringout = stringout + " " + a + "a" } return stringout.trim(); }
Is there similar functionality in Coda as this will prevent a lot of messy formula’s everywhere trying to do this ‘by hand’ each time it’s needed on the document (a lot!)
Thanks
