Hi! I have a peculiar question!
https://coda.io/@vongohren/public-cooking-drinks
I got this doc
One thing I really don’t get to work, is to showcase only the needed data at the right situations. So this doc is all about adding recipes and getting control over your recipes. But I want to “restrict” views of the table entry at certain scenarios. I have partly explained it in the intro, but here is a use case
My problem is this use case.
When adding a new recipe, I dont want to showcase all the data that is not fillable. Yes this is doable and im able to do this.
But when using this table to build a randomizer, it is only possible to reference the main table, the one where you add data, meaning that the view becomes the same as the add data view. Meaning the randomizer recipe, is showin a restricted view with hidden columns. Where I really want to show the full view at this scenario.
Yes, if I only work with tables, I can showcase views of children tables, but is children tables the only way to do this, because if not, the view will inherit the root view. Where adding a row view takes presedence.
It was very helpful and it worked better than expected as well
