Does anyone know the formula for displaying ALL the entries for a set of dates (I was trying for everything in the next week). I tried:
=[Chart].Filter(DateScheduled= (Today() + 7))
but that only returned the entry that was schedule 7 days from now, and not everything in between. I suppose there’s probably an easy way to do this but I can’t figure it out!
I add a column to my tables that takes the WeekNumber from any date I’m working with. Then it’s easier to reference in formulas for things like this. If you created a column named “[Week of]” that was the week number of whatever date you were using, then you could reference it like this:
Hey benn - they way that I set this up is actually using a control - the date range picker.
If you set up the picker and then in the filter for the table just do [the column].matches(daterangepicker1) and it should work easy as pie then you can also adjust it if you want to go back in time or look a month or really anything!
Let me know if this makes sense or works for what you’re looking for!
