I love having the ability to display a preview of content in a Canvas or Compose column. However, there are many instances where I only want the expanded preview in certain views, and not in others. It would be awesome if I could somehow “override” preview settings, perhaps at the Table Display level, or something like that. Or, somehow design a way to set a default, but change it per-view (kind of like how I can toggle conditional styling from a source table).
Thanks for listening!
I would love this as well.
But also the ability to have other column options changeable per view. For example, in some views I only want the date, other views I want to be able to show date and time.
P
A workaround (for display only) is to have a copy of the canvas column (maybe it’s called Notes) with a formula that is simply thisRow.Notes
. Then you can change the display settings of that column to show preview (or not) and depending on the table, include one column or the other.
Thanks @Ryan_Martens2 for the workaround tip. Have been employing that option already, and is a good stopgap.
