We’re looking for a freelancer to help us build up some docs that just need a little more under the hood the work then what we are able to put together, most of it is formula based. The use case is really well defined and its not often something that needs a ton of thought muscle, its mostly problem solving - getting sub tasks into a main task or creating a table that has a default hypelink on the task name to expand it in an expanded row view.
Solutions are usually really well known or what we want to see happen. There may be some exploration work required for some problems.
We need not worry about documentation or extensive admin to execute on the work, this is more agile in nature. It’s just important you can get the work done within a timeline you set for us.
If you are freelancing and building coda docs please reach out.
